Showing low storage warning? Try this!
Tokenpoke
Android Expert
I've discovered that both my l9 and my f6 hold onto the storage allotment for moved downloads...
Not sure if you get my drift...
If you download a file to internal and move it to sd it still shows up in "downloads" when you check the storage in your settings.
To solve it open settings/storage/unmount sd and then open downloads under internal storage and delete files you know you moved.
