Help Shutdown PC with phone connected...?
Hi all.
I seem to remember reading that the LG Optimus GT540 should not be connected to a PC via USB as the PC shuts down.
Why?
Anyone read that or know why?
I can understand if it is in the mounted state, but if it just connected to charge - cant I keep it connected to charge up even though I have my PC set to shutdown at a specific time. The power still goes through the USB even when the PC is off so it will still charge.
Any advice or comments greatly appreciated.
Cheers.
I once forgot my phone connected to the pc wile shutting down and the screen did something weird. it flickered then displayed some static noise. So I wouldn't advice to leave the phone connected, instead use the wall charger , better safe than sorry.
Hi all.
Why?
Cheers.
You guys just need BRAND NEW POWER SUPPLY for your PC. :p
Trust me, I have over 10 years of computer hardware knowledge - working in computers service center.
So whats the deal Djolle?
You reckon it will be ok for a PC to power down with a phone attched?
Wold appreciate you letting us know what damage can be done as I am sure the thing I read was on the LG website.
Ta.
That's never happen to me and nobody I know... except, when pc power supply is old (eg. wornout) - if some of usb devices are connected (especially if that specific device need a lot of power - GT540), PSU cannot keep the pace and Motherbord just do off to prevent damage to the system hardware.
Trust me, you need to buy BRAND NEW POWER SUPPLY. :p
p.s.-At night my phone is charging through my PC USB port, while my PC is powered down... completely. Never ever problems occurs.
Thanks for the reply Djolle,
but I am confused....
firstly, my PC is running fine and I doubt I need a new PSU - it was merely a question I asked and not a statement of experience.
you say the GT540 will be a specific device that needs alot of power... how so? USB is only 5v no matter what device is connected so I cant see how it requires alot of power. It may require a longer connection time to fully charge but 5v is not going to push any PSU at all - surely?
So, even if the motherboard does just power off for any reason, unless it is a spike in power I cant see how it will damage the phone?
You obviously have experience in these matters and so would appreciate your clarification - especially about the 5v matter.
Thanks again for taking the time to reply Djolle and xlomo - it is appreciated. :-)
(EDIT) Thing is tho Djolle, as much as I appreciate your replies, I think you are missing the point. I can see you phone is connected via USB while (as you say) your pc is powered down - but the whole question is what happens if you PC is active and working with phone connected - but then powers down with phone still connected?
Ahhh... sorry, I missunderstand your question.
Any usb device (eg. flash memory stick, joypad etc.) use aa little power from your PC - so if you connect them directly on your mainbord (at the back of the rig) it is ok b'cause your mainboard is trying to keep steady current of power. But... (always a "but") on the other hand if you connect at the front of your rig, there is a little of electronics doing it... and also that electronic board CAN (and very probably if wornout)... CAN damage your USB device.
Hmmm... I don't know... clear now? :)
Cheers Djolle,
That is very useful, I understand what you mean.
Well, I still am unsure how these problems would surface when powering down the pc if a phone is connected as all the problems you just mentioned I suppose could happen at any time so the risk is constant.
But until I get a satisfactory solution I will not let my rig power down whilst the phone is connected via USB - for whatever reason.
Thanks again Djolle. :-)
