fenrix
I do not have a PC. I have fully rooted using gingerbreak, I do not want to change from stock rom. I have installed busy box everything works. I have removed apps I do not use.
I would like to set my voice sidekey to pull up mixzing. I use GoLauncher EX.
I have located a key map or what appears to be a sort of key map it has wake next to
some key settings I havent removed these as I prefer wake functiona as is.
If anyone knows how to using esfileexplorer notepad or the terminal to change my sidekey I would apprecite it. I removed all voicedial apps from system and my key currently has no function.
