is there any app or rom that i can download that will help boost my signal/dbm? Im not receiving at least 75% of my calls and messages, when i place a call it will more than likely disconnect.
Thanks
I have heard of a device that you can connect to the internet and it'll give off cell coverage off of it. This will only work at home though.
You could also look into changing your PRL. If you Google it, you should find some tutorials. There are also threads here on that.
unfortuneately to moto triumph came out of the gate with a weak antenna I ve had mine since july tried every prl possible tried everything posted on this forum and reception still remained bad unless i just happened to be in the range of just the right tower . whole thing really suckswhen you paid $300 for the phone but I m at home 80% of the time and use wifi when needed but haven t missed but a hand ful of calls can t imagine not getting calls 75% of the time have you tried getting a replacement cause i had a replacement with that problem call one morning got the phone the next day good luck
