App's called "Signal Booster." lol
There are a few of them out there, but the one I use is the one with the purple andriod logo.
I like the stick on antenna "boosters" that you can get from some phone stores for like $5. Everyone says they are BS but I have ALWAYS gotten better signal in my house (which is usually where I get the worst reception and its a good benchmark spot). And hell, for $5 how can you go wrong.
Those word by producing a Ferdinand type barrier on your antenna, blocking the weaker signals and electronic noise that is not in the cell wavelength..... so I could see them helping a bit. But the op was asking about an app
)I also tried them on the Samsung admire , when I had it , and it didn't do nothing , and I just learned , SOME SIGNAL BOOSTERS they hack into the phones files and change the signal animation on your notification bar , and it makes it look WOW and sometimes you uninstall it and it doesn't come off!
The app you linked only works if you are stationary... it just locks you to the fastest tower near you ATM....
Oh, and it just force closes and turns airplane mode on for me....
but what screencap app did you use for those vids?
