Help signal issues
You can try a factory reset from the recovery menu. To get into recovery mode, power on your phone while holding the Volume Up button.
You'll get a little screen with some options. Use the volume rocker to highlight "Recovery" and select it with the Power button.
Now you'll have a screen with a triangle and an exclamation mark. Hold the Power button and press Volume Up to bring up the recovery menu options.
Select the option that says "Data Wipe/Factory Reset"
This will return your phone to factory condition, meaning all apps and settings will be removed. Items in your internal storage won't be touched though.
It may or may not help, though. But since you've only had the phone a few days, it shouldn't be too much trouble to go through the setup process again. Also, an update is supposed to come out in the next few weeks. That could fix your signal issues.
In that case it's not because of the Radio version ,it is because of your SIM card [change it !] or something within the software [do a factory reset !].
Old phone + old sim cards = 100% FINE
It's the old sim + newer gen smartphone that is causing trouble !
yes but i found out the the problem is the sim card. i putted another sim card and the phone works perfect. the phone don't accept that sim. i will change it today.
