Help Signal problems. 1X??
geojr
I am having a problem with the signal I get at work. While trying to surf, or stream Slacker or Pandora, my signal changes from 3G to 1X. It goes back and forth messing up any attempt to use the web. I have not changed anything. This seems to be a recent thing. Not rooted. I have done the *228 option 2 thing. Is there any setting, or anything else I can try??
I know long shot, but worth asking.
thanx,
geo
most likely just getting a bad signal in your place of work...when i worked in an office building i would only get 1x, metal roofs maybe? lol
Thanx for the reply. As I said, I figured it was a long shot that there was anything I could really do. Other than find a new place of employment. :)
Has it always done this while you're at work or is this a new problem? You could try doing *228 option 1.
