Hey guys,
Looking for someone that has been using another VM phone and has now switched to the Evo V.
There are two specific things I'm looking for here....
1) Data speeds (3G obviously) in comparison to your old phone. Basically if you used your phone in certain places, what kind of speeds are you getting in comparison in those same places? Better, worse, the same?
2) Overall signal quality. In the same locations are you getting/holding a better signal than you might have on your previous phone. This is NOT about the number of bars, it is signal quality where you might have struggled to get data somewhere but now you either can't get anything or it is better than before.
The reason I'm looking into this is because my area at home is right on the edge of 3G. If the Evo is getting better reception then I can get a better connection. If it is the same, then I'm worried about how well the Evo is going to get data on a weak signal... I don't want to get stuck on 1x when I can at least squeak by with slow 3G now.
Thanks for any info. Actual speed tests would be amazing. In case there isn't much info about the signal and I do pop on the Evo then I'll come back and do my own results for everyone else.
