Help Signal/reception ?
Kg198202
Does anyone know of a wsy to boost the signal? If i hold my phone normally im sitting at -101-106dbm average. If i hold the phone sideways are lay it flat i get much better signal...any suggestions etc?
Thanks
Only use it while lying flat. :D
Seriously your signal is constantly fluctuating, there's not much that you can do unless you're rooted and try to find another radio to flash, just remember that it's a bit of work for a pretty minimal improvement. Good luck. :D :thumbup:
OB
