R reemas Well-Known Member Jun 16, 2010 #1 how do i check in DB what my sprint signal stregnth is? also, what is the triangle icon next to my reception bars? thanks all.
Whiteboyx69 Member Jun 16, 2010 #2 Dial *#*#4636#*#* then go to phone information. The triangle means your roaming.
H Headcase_Fargone Well-Known Member Jun 16, 2010 #4 There's an app called Real Signal that puts two bars in your notification area and gives you precise measurements when you bring up the notifications.
