Well, the antenna covers most of the phone. ( If you take the cover off, at both the top and bottom you can see a thin red ribbon crossing all over. Look carefully and you can see the path for the antenna in there. )
Interestingly, covering the top doesn't have the same affect. The only 2 possibilities I can think of are: A) The top part of the antenna isn't being used. Perhaps it's a the wifi, 3g or gps antenna...or a part of the radio antenna that has something wrong with it? B) The lower antenna is actually the problem, and something is interfering with it and this is why it is so sensitive to the placement of your hand. I'm leaning toward the latter...I don't think your hand shouldn't have that much of a difference!
This is definitely an interesting find though. I had seen the antenna before, and never thought about it. I also naturally just use thumb and index in the middle, which isn't enough to cover the antenna...and surprise surprise, I've always been one with good call quality until earlier today, when I was holding the phone like normal while on the phone, and the other person couldn't hear me!
<begins to strongly consider an antenna mod...only stopping after looking at the $530 price tag and warranty being void.>
Upvote
0
