sookster54
Android Expert
I've only had this Sandisk 8GB (class 4 I think?) for 4 some odd months and I'm starting to notice sluggish behavior when opening apps that are on the ext partition or when the Market updates apps they take a while to install, sitting at "installing...." for 10 minutes or so even though they're already installed. At one point one rom I installed formatted the ext to ext4 and when I flashed another rom I had to reformat it back to ext3 via my laptop. The Fat32 partition seems ok, I haven't seen any odd behavior or corruption with the files on there yet, should I reformat the ext partition again to see if it fixes anything or do a fsck?
