Hmmm, had the same problem still do. Some times no nothing, other times I get my own voice sent back through my speaker. Beginning to wonder if this is a DX problem, originally was blaming Verizon.
Are you using the originial radio firmware? I am on the leaked path so didn't get the radio, bootloader update the OTA came with.
Do a *228
ANd you had it after the update?
Both options?
I had the same problem when my wife called. I did not get disconnected after 10 seconds tho, I hung up after about 30. Called her back about 2 more times, still heard nothing, then rebooted my X and everything was fine after that.
A couple days later I had the same problem, but it was just one call, again with my wife and I hung up and the next call worked fine.
