Help Silent mode question
nickstanley
Is there any way to turn off all sounds except for one incoming number? I like to have my phone completely off by when my ex wife has our son, I'd like to keep it on just for if she calls. Is this possible?
If you get google voice you can set up "do not disturb" and make an exception for the ex's number so she'll still get through. That would be the easiest way.
If that's not an option, search for "call block" on the market. There are several applications that will allow you to block all calls and you should be able to whitelist different numbers.
Maybe someone else will chime in with an easier way.
Did you find any solution????
Pm me
All this was so easy in my previous symbian phone!!!
