TheGroovline
So iAllowed My Friend Use My Phone For A Sd card Switch He Pulled The SIM Card Out Now iNeed Help It Says "Insert MetroPcs SIM" But Its In If Theres A Fix Let Me Know
Try shutting down the phone. Open the back and make sure the sim card is correctly inserted. Than power it on again.
Having The Same Issue
Its probably backwards. Try it the other way.
Lmao No The Upside Say Do Not Remove...
When inserted you should only be able to see the light grey numbers. Can you see "do not remove" while its in?
So Many Thanks Yo So Many
