rushmore
Extreme Android User
Rather than debate or worry about the signal topics brought up about the Nexus, simply test in places where you know are weaker areas or compare in specific places you know you got good 3G and 4G signal. The convention here is you have another device to reference.
Suggest not looking at the dBm signal, but test several higher def Flash videos from a a few sites and see if plays back well. This will provide a good indication from a practical standpoint, rather than debate if the dBm is correct or not.
None the less, the wifi does seem to be weak on the Nexus and that is very simple to test.
Practical tests that yield results tends to be the best method to apply perspective.
