Help Simple Background Settings Question
seoul1881
On the LG Optimus V, I have changed my background wallpaper to a live wallpaper. However, everytime I turn on and off my phone the wallpaper resests to the orignal Optimus V wallpaper. Where is the setting on the phone to keep my live wallpaper? Also, I'm using LauncherPro free. Thanks:)
Weird, it should be keeping the setting. Is that every time you lock your phone, or actually reboot it? Have you tried a different launcher?
I only have this problem when I reboot. I'd like to stick with launcherpro, other than this background setting issue, I'm quite satisfied.
Is the WP on your SD card? Sometimes LP reverts random things on reboot if they're on the card. I have one icon that does this when I reboot, too. Makes no sense, because there's a bunch of other stuff on the card that doesn't do this. No advice really, just wanted to let you know you're not alone.
