the mytouch 3g slide as long as it is for tmobile you can use it with simple mobile and it doesnt need to be unlocked. you can use any tmobile phone and it will work without being unlocked.
the mytouch 3g slide as long as it is for tmobile you can use it with simple mobile and it doesnt need to be unlocked. You can use any tmobile phone and it will work without being unlocked.
