Assuming you mean a mod that affect theming, the answer is *probably* not, but it depends on a few things, such as what the ROM was designed for and what exactly it's changing (theming has to be done in just a couple framework files). As a general rule, you're probably fine, but make sure the mod is known to be compatible. Do you have an example of something you want to try?
