Hey I felt it was a bit hard to follow the directions posted on how to restore your recovery after clockwork or allyRR (custom recovery) on a rooted ally so that ota updates will work correctly.
-If you are not rooted install a app called astro from the market and install universal androot from your sdcard ( http://androidforums.com/ally-all-things-root/161744-universal-androot-beta.html )
Anyway, here is my simplified version. It was tested on windows 7 x64 and x86
props to drellisdee im just restating his work
(http://androidforums.com/ally-all-things-root/146564-ally-recovery-img-here-custom-roms.html)
The file links are on his post and elsewhere on the fourm
-Download-
android sdk (found on official android site)
flash-image (needs to be unziped)
stock_recovery.img (thanks to drellisdee)
install android sdk to C:\
install Lg Usbdriver - if needed
copy flash_image to the root of your sdcard (remember to unzip it)
copy stock_recovery.img to the root of your sdcard
run cmd (windows command shell) as administrator by left clicking it
/ cd C:\android\sdk\tools (sdk's tools directory)
/ adb shell
/ $ su
you should have root # prompt on you phone, allow acess.
/ # mount -o remount,rw -t yaffs2 /dev/block/mtdblock4 /system
/ # cat /sdcard/flash_image > /system/bin/flash_image
/ # chmod 755 /system/bin/flash_image
/ # mount -o remount,ro -t yaffs2 /dev/block/mtdblock4 /system
/ # flash_image recovery /sdcard/stock_recovery.img
/ # reboot
now your done ... wasn't that easy lol
...if you wanted to completely revert to a stock 'out of the box' ally flash the lg v6 rom first then fix your recovery second
thanks to death2all110(http://androidforums.com/ally-all-things-root/166588-how-flash-stock-lg-rom.html)
Finally i have to recommend flashing first the vzb deodexed and radio rom, then velocity 2, then the new v4 jit oc kernel and install adw launcher and set cpu @ 740mhz for max performance/max stability if you want a rooted ally... personally i used allyRR to achieve this, it personally gives me less trouble than clockworkmod... all of these file can be found on this forum or market.
-Download-
/ adb shell
/ $ su
/ # reboot
