Ive been able to talk and surf the net at the same time since day one on my lg ally when connected to wifi.
So I have never understood the statement you cant do that on verizon.
But I will be buying a Dinc2 tomorrow and I suspect it will work.
I'm more wondering about 3g video calls using that front facing camera
On AT&T you can talk and surf WITHOUT Wifi, just using 3G. This is only possible with the Thunderbolt on Verizon. The dInc2 will not have this feature. You will not be able to talk and surf using 3G ONLY.
But talking and surfing on Wifi will work, as it does on every device.
Is that speculation or do you have the phone?
I do not have the phone, but it is not speculation, it is fact.
The Thunderbolt has a completely different radio inside of it, the radio that is required for simultaneous voice and data over 3g. The dInc2 does not have this radio.
Really, what radio is that?
Far as I can tell Dinc2 is EVDO.
I see you have a dinc2. in order to settle this issue once and for all, why not give it a shot and report back here?
Okay... Here are my results.
Phone + WiFi = Data!
Phone + 3G = No Data!
Hope that helps!
Hope that helps!
If it is a 4g phone, then yes.
