Since upgrade Bluetooth Horrible
I have the same problem although I never used it before the upgrade. I did try my Bluetooth headset on my Blackberry and crystal clear. I have the Plantronics Voyager Pro.
my BMW can't even connect to my Evo the way it should anymore... alot of 'bad connections', or it would drop in the middle of the call. when it tries to transfer contact list, it crashes
My Sennheiser MM 200 still sounded the same. I use it everyday now, not as good but good enough and more convenient then wearing wired headsets.
Have the Jawbone Icon Hero; before upgrade: crystal clear, --since: snap, crackle and pop. What gives?
Went to Sprint and they wanted to do a hard reset--NO WAY. I'm just using a wired headset and waiting for FROYO.. hopefully It'll help.
My quality stayed the same, but I have run into connection issues. I have to turn my headset on and off a couple to times just to get it to pair correctly and sometimes it will just disconnect the headset for no real apparent reason. I have a Jawbone Prime.
just upgraded my Jawbone Icon to A2DP. So far ,,,very kool. I can now listen to music on my b/t and navigation (GPS) Don't know yet if it fixes the : snap, crackle or pop on the voice call ..there's always hope
compatible phones for upgrade
Answer
not saying this is the problem but having the hearing aid thing on was giving me all sort of sound problems. so check to make sure that didn't get turned on by accident.
