should i do this? http://forum.xda-developers.com/showthread.php?t=1840030
I hope Shotty doesn't mind me interfering... but I can see your problem straight away. You are using the wrong Siyah kernel to try and root your phone on ICS, Android 4.0.3!
See the Rooting Galaxy S2 - Dummies Guide, posts #1.5 and #1.7 for the correct kernel. Please read through all of the first 3 posts in the thread to give you all the information required for rooting the SGSII.
Hope that helps.
hi, what should be mounted in recovery mode and hwat should i format?
i have flashed my phone 3 times now with the siyah v 5.0.1 now but it still fails reboot. and when i go into cms recovery it says that i still have the old siyah v6.0b5 kernal that i first used.
Installation instructions (please read carefully and thoroughly)
You will need to be rooted, see here, and have ClockWorkMod, (CWM), installed.
I too have found siyah v6.0 b5 less battery friendly than siyah v6.0 b4.
Ended up going back to neat rom 5.0 , alls well now .
With 5.3 the phone want going to sleep for some reason and the battery was draining very quickly .
Try Apolo 4.12 kernel. Siyah project is dead...
While what you said sure is true....is it worth the switch? What version are you currently using?
