Help Skype silently exits
shturm
I often find that Skype is not running when I expect it to.
When I start it, it works just fine. During the day I check it periodically and find it still running. But then at some point (after minutes or hours) my routine check triggers start of Skype, which means it silently died since last check.
Is this a known problem?
Is there an idea of what might be causing this?
In the meanwhile, can I use Tasker to monitor status of Skype application, and restart it automatically if it is found not to be running? How?
Thanks!
