Root SkyRaider 2.5 GPS problem
ohm911
has anyone confirmed the issue with the GPS on Skyraider 2.5, becuase my gps current location is off by bit, and i was wondering if this would be ok with radio uploaded to 2.15 i currently have 2.05 can any one confirm this?
also if i wana downgrade my Skyraider one verison how would i do that?
thanks
You will need Forever to go to 2.15. Which version do you want to downgrade to and why? Probably a full wipe is needed if you have the Rom somewhere. You do know he's releasing 3.0 very soon.
hi i really appriciate your hel. i will update my Radio to 2.15 also in future if he realse 3.0 how would i go on upgrading from 2.5 to 3.0? just use put it in root of SD and load it through Rom manager?
thanks once again
