I am about to try skyraiders for the first time. i will say that chads are always the best for my sense and vanilla roms. i disagree that they are unstable. speed is great. charging time is amazing as well as battery life.
again i am about to flash skyraider now for the first time and will report back with results.
Oh thats great! I had read a couple of threads and most people had said that it was really laggy for skyraider, but atleast theres hope! Are there multiple versions of chad's? if so, which are you using? I just flashed king kernel #6 bfs (which i believe is the one for sense, and cfs is for vanilla) which is overclocked to 1190 mah i think, something like that. people were saying they had great battery life with it, but I was a little skeptical because it's overclocked and I dont see how an overclocked kernel could do better than a stock speed. I'll test it out for a bit and report back, keeping my fingers crossed!
Edit: King Kernel BFS #6 has far surpassed my expectations as of now. I charged my phone to full without bump charging, so in effect the battery level was probably somewhere between 90 and 95 percent (plus I just recently cleared battery stats which made the level drop more quickly for the first few minutes, bad idea). I browsed the internet continuously for about 30 minutes, ran probably 5 or 6 quadrant tests, sent quite a few text messages, and I also use launcherpro, basic things that can tend to drain the battery. While I was browsing, I noticed that battery level dropped much more slowly than it had before, even though I was overclocking; weird, but awesome. The browser seemed slightly faster from what I could tell. I am now at 50% with stock battery (probably would be 55% or so with bump charging) with almost 5:30 of wake time and almost a full 2 hours of up time. I am very impressed. Quadrant scores went up about 100 points on average (now in the 1050 range), but I got it over 1260 at one point using setcpu at max (min and max set at 1190 mah) and overall performance has been good, no lag or anything. Charging time has also seemed to improve over adrenalyn's kernel.
I think my setcpu settings were also beneficial for battery life, and I would recommend these settings for you as well: 1. a profile to underclock when screen is off (mine is 248-384 mhz) 2. a profile to underclock when battery is hot just in case (>39.7 C, 245-578 mhz) 3. SET SCALING TO CONSERVATIVE if it is not already. This is a big one as it will keep the cpu at low speeds when it doesnt need to be at high speeds. I don't think it will slow your phone down at all though when you're doing something that requires high cpu, it should overclock just the same 4. Go to advanced in setcpu and change Down Threshold to a higher number. This will cause your phone to slow its processor based on how much cpu is being used (I set 40%, so it will slow down the processor once 40% or lower is hit). This will allow you to save power when you're using processes dont need much speed from what I understand. If you wanted you could play with the other setting like Up Threshold and Freq Step, I havent really yet, and report back to help the rest of us out! I hope these tips help you.
Over all, I'm very pleased with the kernel. It basically gave me what I had wanted in a kernel, now I just hope this performance becomes consistent.
