Root skyraider questions
I just got an incredible and am currently running skyraider 3.5. I thought that the browser was supposed to be modded for hulu but I'm not able to watch videos from the site. Is there a way to make the notification panel display the recently used apps instead of the power controls? I'm also curious about how you change the look of the lockscreen. And when do you think skyraider 4.0 be released? Will it include the new sense features? The skins, the updated camera and browser? Thanks in advance for all answers!
I checked the app drawer and couldnt find it. I'm also wondering if its ok to use setcpu with skyraider or if the rom itself takes care of its own speed and power management?
I had the hulu app in mine. It was a green "H" if I remember ( I uninstalled it). For the most part the kernel does it's best to control everything. You may want to get SETCPU if you want to see high quadrant scores (totally worthless though). MY personal opinion is to use Ziggy's Kernel BFS. That's what I use and I have unbelievable battery life with it. I did try Skyraider with the stock kernel, Hey it's Lou #6, and Ziggy's kernal from Jan 2nd and now I'm running his from the 15th. I'm happy with it.
Best of luck.
IHTFP69 has taken a leave on making ROM's so SR4 is on hold right now :( major bummer. I have the Hulu app and it doesnt work well so I never use it. Try using the Skyfire browser and just go to the Hulu site.
Im using SR3.5 with Lou #8, really happy with performance and my batt life is sick right now. A whole day, go to bed with 70% left! I still cannot believe it myself.
