Jarpee
I'm running SR sense 4.2 and really like it so far but I have a few questions:
1. The youtube app will not work, whenever I dl it from the market and try to run it it FCs and then the app doesn't show up in the app list, to try again I have to re download it from the market. Anyway I can fix this?
2. I believe the kernel that comes with the ROM is the stock kernel. Has anyone had better performance or battery life using another kernel? Also can I flash any sense kernel or will only a specific few work with SR?
thanks!
thanks!
