Ok, so if I do the ICS leak install without rooting, and then the actual update comes out, will I still get the update or am I totally good to go?
Ok cool, so where do I download the ICS OneClick?...Google Play?
OK, so do I download the file from my phone and run it, or do I download from my computer and install it that way? I'm new to this stuff.
Download the zip file to your computer....I used SuperOneClick to install it. Power off your phone, and while holding the volume up/down at the same time, plug it in to the computer and let it boot up into download mode and then click the zip file and let her do her thing.....it took about 15 mins for me.
Works like a champ....oh, and back up your files...hell, take out your sd card. I forgot to do mine and lost everything...lol
So was ICS worth it? Or, is just a slightly different touchwiz. Someone please post a review.
When you update os do you lose all your apps and saved data?
How do you know when the official update is out? does it just pop up on your phone
