Help slide on lock screen
When in lock screen, no pin/password, the slide has 4 directions to unlock, can you add to these directions, so only 1 unlock and add to the other directions such as silent, vibrate only etc. Bob
I don't know what options it has for sure, but you probably want to take a look at Widget Locker
+1 for Widget Locker. Allows you to put a circle with up to 8 apps or actions to unlock to.
I have a browser, LED light, silence ringer (I was so used to this from the N1 that I couldn't live without it), as well a the camera a calculator, and voice search.
You can also do more traditional slides (multiple if you wish).
