Justinlara313
Member
Have there been any reports of the sliding mechanism on the shift getting loose? Or even breaking completely?
Mine's brand-new and a little shaky after only a month. Not outside the range of acceptable....YET. It has about 3/4th of a millimeter play in all directions.
Not as bad as what people had to deal with when the Palm Pre came out ("oreo effect") but definitely not rock stable. In fact, the slide-out keyboard on the crappy old L3 Rumor2 I got for free in 2009 is much more stiff after all this time than the Shift is after just a month. Hmm...
I can barely slide mine open![]()
When I first got my Shift in February the keyboard was quite stiff to slide open. Then, after about a month, it suddenly felt as though it would slide open with a strong gust of wind (im gravely over-exaggerating).
All you guys with loose sliders should buy an otterbox commuter case for it. It just about locks the thing closed, and it's a GREAT product.![]()
