Slider won't charge?
jdean48
Lately when I plug the charger into my lg optimus slider it does not charge. The only thing that happens is the charger itself, that is plugged into the outlet, will start beeping. Is there any way I can fix this and be able to charge my phone again?
Are you using the OEM charger? They vary slightly, sometimes significantly. My wife's slider wont charge if she uses the cord that came with daughter 's S3 and constantly reboots while plugged in. Try using OEM charger. If that does not help might be a worn out battery.
