Help Sliding issues
Rollout
I seem to be having an issue with sliding lately, takes about 4 tries to answer a call, switching screens is hard, scrolling, etc....
Any suggestions?
I've noticed the issue as well. Wiping/drying the screen(even the parts underneath the case if you have one) seems to work well. It seems sweaty or oily fingertips can cause problems with the conductivity of the screen.
Oh, I took the issue as lag. Yeah just make sure it's clean. Use a soft cloth and a small bit of water on ur finger
Rollout clean you cache i use this app found here( 1-click cleaner)https://play.google.com/store/apps/details?id=cn.com.opda.android.clearmaster&hl=en I highly recommend it Or just pull the battery for a min or two.
