Help slight annoying problem
voodoo25
hi guys am new to the whole android thing, i have the sony ericsson xperia x8.
one thing i got told was to download the advanced task killer, anyways everytime i kill the apps and games i dont use it makes my signal go off for about 15 seconds then back on again, which i dont mind. the thing that is bothering me is the service tone, it gets realy annoying, i have tried to see if i can turn it off but it doesnt say anything in the user manual.
any ideas? or could it be the type of task killer i am using?
I think it's only the type. There are lot's off task killer apps out there :) I use Advanced Task Manager and I love it :) Place the 1x1 widget icon on desktop and you can easily kill all tasks :)
just put BACKUP&RESTORE in the task killer ignore list
cheers guys, it solved the problem. now i also wondered if i can disable the service signal tone, as in my area its quite poor signal and my phone is always bleeping.....rather annoying.
i dont have such thing on my phone lol
maybe you must have installed some software related to network
