Help Slight Problem
mdside71
Ok i had some problems with battery life on CM6 and CM7, so i cleared everything in CWM, and flashed it back to stock. However since doing the stock flash it does not keep the correct time. I can go put it in airplane mode and manually change it, but as soon as i reboot it goes back to being messed up...Any idea's on how to fix this?
go to settings/date&time, un check automactic, now select your timing zone, than check automatic again...
