Help Slight stutter
MidshipAc
I've noticed a slight stutter while playing games like Jet Pack Joyride and Robot Unicorn Attack [most noticeable in side scrolling games/distance based games] I can't seem to figure out what it is . It seems to be randomly happening . It isn't the game because it is not constant. Any body else experience this?
If so download kernel tuner from the market, set both cores to performance governor, make sure both cores are enabled, and that should stop any stutter while playing games. They are set to ondemand2 by default and the second core has a tendency to disable itself to conserve power.
rooted with cwm. wont softbrick or anything like that right?
