I have a Slingbox Classic that worked fine in OG Droid 3g & wifi.
I have NOT got it to work right (without sputtering) on Droid Bionic via 4g.
Works on Bionic via wifi perfect.
Any advice? Thanks!
Just running it now over 4g to test again (10 minutes so far), seems smooth.
I have 2 HD slingboxs. One is just hooked to an SD box though. Watching the HD one now. Once on each of the slingboxs (after a few seconds of starting the stream) I saw the spinning saw icon (buffering) but no type of sputtering after that initial buffer.. have full 4G bars at work though. I used it briefly at home with 1-2 bars couple days ago, and it worked the same. Have you tried updating the firmware? I think you have to login through the web interface, or the oldschool desktop software to see if there is an update for the slingbox firmware.
-droidosis-
