slinky
After a few weeks of great battery life I've been dogged by battery drain of
Android System
Kernel
Android Core Apps
system
roid.sviewcover (I don't use a Samsung sview cover)
I thought that maybe it would be other apps in the phone but it appears not. I've turned off all of the usual stuff but still the phone response is painfully slow for its processor (yes, I cleared RAM) and the battery life gets me 3 hours of screen time, maybe a bit more. I wonder if Outlook 365 and Gmail is causing a battery drain that is part of but not reflected in the Android system. All those apps seem to generate little battery drain (15 minute fetch) compared to the Android system burning it up. Those of us on the Note 3 use 4.4.2 and there is no other option, on a T-Mobile phone. Very odd.
Android System
Kernel
Android Core Apps
system
