Root Small flash problem
Matt H
I fully rooted and flashed using the rooted stock rom. I am wanting to change to Fresh Evo 0.3.
I hold the volume button, power on and get to the white screen. Once I scroll to Recovery and select it, it flashes a HTC EVO on a white screen. I am not able to do the volume up and power button step, but I am in Android system recovery, and not this screen.
The one I am at lists:
- Reboot system now
- USB-MS toggle
- Backup/Restore
- Flash zip from sdcard
- Wipe
- Partition sdcard
- Other
-Power off
What am I missing?
Well I went ahead and did flash from sdcard, then update, and then it went to clockwork, so it looks like I'm all set. Flashing to Fresh now.
I was confused because it skipped a step. :)
Flashing is A LOT easier than I expected.
Now I have to reload all my contacts manually since I didn't back them up. I figured Titanium would have backed up contacts and I never sync'd it with Gmail.
titanium does back them up...just restart the phone
