t-readyroc
The one time I actually had the "Smart alarm" function checked for my daily alarm, the alarm never went off. I have my alarm set for 6:20am, with 1 ten min snooze. After un-checking Smart alarm, the alarm functioned just fine.
According to the manual (p.142):
Has anyone else used this feature with any luck? Care to share some wisdom?
*Edit - just found this, but again, no discussion of having to put it on your bed. But if you look at the promo vid (youtube/watch?v=dTQVRCC8xiA), you can see that the dood clearly has the phone on the bed next to him...
So... the alarm senses movement? I'm totally lost on this one. The only worthwhile Google search result I got says that:Smart alarm: tracks body movements and calculates the best time for sounding the alarm. Place the phone somewhere on your bed then the phone's movement sensor (also known as accelerometer) is sensitive enough to work from any part of the bed. Set the Duration and the Tone.
Ok.... but what about the whole accelerometer thing? I also searched in the Galaxy S forum for an answer, but came up with not a single thread on this.The Smart Alarm wakes users up with soothing, natural sounds, while the display slowly lights up – similar to an artificial sunrise. The alarm starts off quietly so the user doesn’t wake up quickly and it isn’t harsh to the ears – it continues to get louder until the user turns it off.
