smartpad reset (haipad mid701?)
gerobaker
Hi, I have bought a new? smartpad (haipad mid 701?) but it was already password locked. i have treid to factory reset, but can not find the correct button combination.
There are the following buttons
on/off
vol up/down
menu
home
All on top
back button on face
reset button on bottom
Any help welcome
TIA
You bought it supposedly new and it's password locked? Bring it back and ask for a replacement. (And if you're in a civilized country, selling a used item as new is probably considered fraud [it is in the US], a criminal charge, which you can remind them of if they refuse to give you a really "new" one.)
You didn't give the full device info but try this
If your tablet fails to respond when buttons are pressed or when the screen is tapped, you may have to perform a hardware reset on the tablet to restore functionality. To do this, simply use a small, thin object, such as a paperclip, to press the recessed reset button located on the side of the tablet. In the event that the Android operating system starts to slow down, becomes corrupted or otherwise unusable, you can reset the software back to factory default configurations and have a fresh start. To do this, use the following method: Note: This process will erase all of your personal information, all stored contacts and any programs you have installed on your tablet. From the Apps menu, tap on Settings, and then tap Privacy. Tap on Factory Data Reset, and then tap Reset Tablet. Tap Erase Everything to format your tablet back to factory default configuration.
