Help SmartSwitch or GoogleTakeout
  • Start date Start date
A
Android Question
Guest
Hi
Is Smart Switch or Google Take Out better?
I use Takeout easily but watched videos of SmartSwitch and it seems Takeout is easier and is less complicated.
What do you think?
What device(s) are you using, and what are you trying to achieve?
Samsung Smartswitch is designed to migrate data from one smartphone to another Samsung (only) device. If this is your scenario then it's by far the easiest option as it's a very simple process.
Google Takeout, otoh, is designed to allow export of Google account data to almost any platform. The downside is that more manual intervention is required to ensure that this data is restored to the correct place.
