Root Smoother Animations
parkerskouson
Ok. I wanna get Evo Deck. But the animations every on the rom are just so choppy! Is there any way to the the animations on the rom any smoother, or is that just how the rom runs. I mean like miui animations smooth.
IF you know of any way to make that happen, let me know.
Parker
Parker
are you talking about the boot animations?? or just they way the rom itself runs??
Just the way that the rom runs. Like switching screen to screen and stuff like that.
well, you can try switching kernels....you can try running the V6 supercharger script....although with Evo Deck being aosp it should run pretty smooth as is...i would try the first two i listed and see if that helps....some roms just dont run well on some phones no matter what you do....i tried running Synergy RLS1+godmode awhile back and the lag was unbelieveable...it didnt matter what kernel i used or what script options i used...it just plain out would not run good and i had my sd card partitioned...
Should i do this before or after i flash the rom? or will it be removed once i switch the rom?
do it after you flash the rom...and yah it will be removed if you switch the rom....you'll have to do it over...once you've done it a couple times it only takes like 2 min to set it up.....
Ok. How long should it take to install busy box? its been sitting here for like 10 minutes not doing anything.....
are you in the market screen trying to install it?....try getting out of the market completely and go into your apps and see if its in there...
ya.. im installing busybox and it has been saying "pleast wait while we locate Bu..." thats all i can see and its been there for 15 minutes..
its probly hung up somehow...i dunno why but the market does that sometimes...id try getting out of the market by pressing your back button then go back in and search for it and try to redownload it...if that doesnt work, id go into your recovery and wipe the cache and dalvik cache and reboot...then go into the market and try it again...
do you have the pro version??
uh..... it wont accept any of the versions of busybox that work with the v6 thing...... is that bad?
you tried all of them below the one it says to start at?? just try using one above it...it might be ok now since the update of the script....
im in the script manager and now it says that the data folder is forbidden
ok well, do you see the 99supercharger.sh file anywhere else if you cant get in that folder?? thats the file you need to find...
you are using Busybox installer right?? and not busybox....there are two different apps
