staffsmatt
Hi, I'm looking for an app that will repeat sms notifications until the sms is read.
First a bit of history
Now I've tried Handcent (it doesn't sem to play very well with smart keyboard pro and is far bigger than I need ie just the repeating alert)
Chomp is again too big and seems to send multiple texts (at least for me)
The closest app I've found is sms popup but I don't really need the popup or to replace the initial notification from the phone (just the repeated reminders bit and I can't find a way of having one without the other)
Basically all I'm after is an app to use with the default messaging app that will repeat the notification if an sms is not read (not replace the existing ones).
Sorry for the long post!
Now I've tried Handcent (it doesn't sem to play very well with smart keyboard pro and is far bigger than I need ie just the repeating alert)Chomp is again too big and seems to send multiple texts (at least for me)
