SMS question
yeahright
I was replying to a text from my friend and i noticed my girl friend's name on my screen over and over. If i try to click onto one of them it just says "loading" then loads back into the same screen. Any ideas what is up?
Extra info:
2.1 leak 2
use SMS popup and the stock SMS
I used to use handcent but it gives me the "message not sent" over and over so i switched to SMS popup.
Thanks.
Edit: I also can not delete them which is really annoying, and they are still there after rebooting my phone... I hope someone can help me get rid of these random extras.
Did you try using an app like SMS Quick Delete to get rid of them?
Thanks. I actually instead of long holding and hitting delete i hit the menu button and deleted them all and it ended up working.
But sometimes i get a random 1234567890 number that shows up like these any idea what that is about? It goes away after i text someone
