Help SMS sending to many messages
zeon9881
I keep getting this prompt every time I send a sms
Messaging is sending a large number of SMS messages. Do you want to allow this app to continue sending messages?
Deny Allow
I can't seem to find a disable feature in the settings menu anywhere. This starts happening after about 75-100 messages, then it starts to prompt for each message I send. Its VERY annoying. I tried google for this but I couldn't find a fix or any thread related for this.
I'm running:
Galaxy Nexus GSM
Jellybean ROM 4.1.1
I'm running:
Galaxy Nexus GSM
Jellybean ROM 4.1.1
Are you using the stock messaging app or a different one?
I'm currently using the stock messaging app. I really don't want to reinstall my ROM, I just finished customizing my phone like I like it.
I am also running Jelly Bean 4.1.1 and have the same issue. I've tried other applications GoSMS and DWP Contact Group Manager but get the same annoying message when sending a large number of messages. Is there any solution to this?
solution is rooting and modifying the limit. For some reason it's set to stop you at 30 texts per 30 mins. Insane at the amount of texts my wife sends me and I have to reply to.
Alot of custom ROMs have removed this limit.
SMS Limit Unlock? It lets you completely remove the limit, or if you still want it but you want to change the number of messages you can send every hour it allows you to raise the limit up to 2,000 messages.
You can find it on Google Play, worked for me :)
