Help SMS texting problem
Hello all! I have a problem with my galaxy note 2. Previously, I had a galaxy S II and when i texted someone and they texted back the messages were staggered like a chat window. However, With the galaxy note 2 it moves all my messages to the top and the person im texting messages to the bottom...it makes it incredibly hard to look back at conversations...is there a way to fix this?
That's odd. All my text messages are staggered. Have you gone through the settings (in the Samsung text messaging program)?
Messaging - Menu - Settings - (Scroll down) Make sure AUTO COMBINATION is checked.
(this is the only thing I could think that may be separating your text)
yes I have gone through the settings...could you perhaps tell me your settings or what settings you might think pertain to that?
What version do you have. I'm thinking these are some of the variations we'll see between all the G-Note 2's. I received my international version today and after booting it up, I did notice slight differences, but nothing major.
What version and/or provider do you have?
Not sure if this is the same problem i was having with my Galaxy S3 but if it is, Your out of luck with finding a fix. When i would be texting someone, all of there replies would show ABOVE mine.. meaning i had to scroll up past my message to see there new message.. it was a pain.. I swapped sims ( AT&T ) and that did nothing.. I used a 3rd party text app and that was OK but i hated using a 3rd party app.
One night i decided to do a hard reset and clear out the whole phone to how it was on day 1 and reinstall all my apps, etc, etc.. and that did the trick. My guess is, that a app i installed somewhere down the road ( and uninstalled ) was messing with something.. because once i did a clean install, the texting issue was gone.
I have the Note 2 now and dont have the issue.
