sms time stamps are not correct...
Bib
i am getting soo annoyed with every answer i am getting
to fix the text messaging issue you need to delete your current inbox and start over. then all new messages coming in will be ok,
using handscent and sending a MMS i get "nationwide coverage not available" hmm
i did this and deleted all my text threads
and the following text i receive
its the same result...
the time appears 3 hours ahead...
zzzZZzz
i am using handscent sms
i live in las vegas
i need a solution
If you're running the leaked 2.2 or new version what i did was download another build.prop from ROM manager. After that i noticed they were fixed. I didn't specifically do it for the time stamps but rather the market fix.
Hope this helps. Sorry if it doesn't.
zzzZZzz
i live in las vegas
i need a solution
my above solution did work for a day. but now its back to being out of order. my times are correct though
