Help SMS times
gamom89
I used to have the LG Dare and when I sent a text message it would tell me what time the message was received and when I received a message it would tell me what time the sender sent it and when I actually received it...is there an app that will do this?
Depending on what SMS app you are using it should do this for you. I have used Handcent and am now using the stock messaging app. Both will give you that information.
Stock: Menu>Settings> Put a check in delivery reports you can also scroll down a bit more for more reports.
It's similar with handcent as well.
