enable to long sms option: making it to send 2 sms instead
How do you do that on the stock, built-in, Messenger please?
actually i coudlnt' find it either but it was supported in my old phoneYes, please let us know how to do so!!
k i just searched the web u need 3rd party sms app to do this
You should not need to enable anything. In the Stock standard Messaging on my SGS2 the count just above the Send button counts down from 160, if you go over it starts again at 160/2 meaning 2 SMSs will be sent. Don't know how Sam142000 makes it convert to an MMS?
The only way the standard SMs converts to an SMS on my device is if;
- You attach some file or contact etc. by hitting the paperclip or
- hit menu, more, add a subject line to the message
If yours is misbehaving I suggest you talk to your carrier - there may be some setting they have that conveniently defaults to MMS because they are usually cvost more!
I dont do anything to convert it, once i sent a sms of more than 4sms length and my phone automatically converted it to mms.
I dont remember the exact message it showed.
Why dont you try sending a sms of >4sms? Then lets see what happens!!
Mine does the same,what carrier do you use? Im on T-mobile UK.
Miss Diva
Miss Diva
Spoke to O2 UK and they confirmed that if your message length exceeds 3 sms's then it auto converts to MMS.
That is why I posted a message above (up there)(no further up) how to over come this problem, but looks like no one is interested.![]()
I too am having this prob with my SGS2 on Orange (debranded) I have raised it with Orange themselves, as I have unlimited texts on my talkplan, but am charged for MMS - So when a friend sends a long text to me, and I forward it (usually jokes) I will be getting chrged for an SMS @
PEOPLE, I have wrote in here of by passing MMS, its working for me, I don't know how clear I have to be. All the networks give us UNLIMITED TEXTS but then charge us for MMS when it is a normal text.![]()
I Just had the same problem.My SGS2 automatically converts a really long sms to mms while sending!!
Is there anyway to disable dis on a non-rooted phone?
